Screeching noise
Old 04-18-2002 | 03:34 PM
Spot's Avatar
Re: Screeching noise
check your fluids and make sure they all look normal. if oil is milky looking then you may have a small head gasket leak and gotten coolant into it. If so, then do NOT drive the car until it's repaired.
what do you mean "appeared to cease"? do you mean seize? if it seized then it would not have restarted. if cease, then you mean it appeared to just stop running or did it actually stop running? Sorry to be picky but it might make a difference. I would be hesitant to drive the car until you find out what the problem is. Otherwise you may make things worse (or non-fixable...).
Old 04-18-2002 | 05:44 PM
ZenArcher's Avatar
You check the belt's and pulley's? I had a pulley seize up once and burned the belt off. Lots of smoke. Looked like my engine was on fire.
ZenArcher
Old 04-20-2002 | 08:28 AM
Spot's Avatar
If it didnt leave any clues behind then the problem will be hard to find. Try making it happen again but keep an eye on your gauges. This may be a detrimental thing to do though so proceed with caution.... Make sure all your fluids are good first and be ready to jump out and pop the hood real quick or it'll leave you baffled again.
Old 04-24-2002 | 12:28 AM
ZenArcher's Avatar
you so many smart bugsbunny
ZenArcher
Old 04-24-2002 | 08:04 PM
ZenArcher's Avatar
Yep, sounds like Jeff87nt kinda stuff. I wouldn't have to look in this case though. Sounded a lot like my 280 when the pulley seized but I had more smoke and the first thing I saw and smelled when I opened the hood was melted rubber. It was a dead giveaway. Sometimes a little scary to pull the latch and raise that hood The more I learn about cars the less I desire I have to learn more,lol.
ZenArcher
tennisman93
11-28-2011 05:20 PM
turbojohnny
30
06-18-2009 11:36 PM
NateB
01-03-2006 08:03 AM
assimilated420
02-08-2005 04:27 PM
G00DHUM0R
11-20-2002 09:03 PM
Quick Reply: Screeching noise
