should i buy for 500$ ?
i found a 93 300zx tt with 110,000 miles it has no transmision and the turbos were takin off i think the motor is ok its an automatic car but i would do a five speed swap he wants 500$ for the car the body is great but needs paint and interior is it a good deal?
jump on it ! 500 dollars for a rolling chasis is perfect start . if i had the chance i would buy it and buy a Jdm Motor off ebay and swap it in.. make sure the wire harness is still complete with the ecu. Check to see if the fuel pump works... Put in a battery and turn to key to hear the fuel pump starts to pump or turn on. your hard pressed to find a TT at all now adays all the ones i have seen are the 1990's if i had to pick i would get the 1994 or 1995 tt my 2 cents, Ken
well i bought the car so i guess im gonna get started ;-) one thing i was wandering tho is i know it can be done but how hard is a five spped swap?
chisle out pilot bushing cause it the auto one, get manual pilot bushing And idk if auto has the 3 plugs like manuals . But good startfor rollings chassis. i got my na 5speed for 900 bucks lol drive but shitty. fixed now good luck
your gonna need drive shaft but rear diff should be okay. if u had a na and u put a tt in with tt trany the rear diff will bolt up but u get a little bad mpg. NA diffs i think have shorter gear ratios
From: The Emerald City from the Wizard of Oz! Dope it out.
I'd Haggle. Just about any running car is worth $500. This ain't running. Offer $375 and go from there. It's worth about $225 in scrap.
This thread died 3 years ago... deep-6-time.
