supercharged Z31
#26
yeah, they do produce less heat. they don't take up nearly as much room and are easire to install. a roots or screw produce more stress on the engine. and they only produce their peak psi mid-way where as a centrifugal stays with the rpm band.
#27
Originally Posted by Bleach
A while back I saw a website where someone documented their build of a white Z31 with a supercharger and turbo. It was done well. I think the license plate was BEATMYZ
- - - edit - - -
http://members.tripod.com/beatmyz/88seturbo.htm
I found the page. Its really old... the owner is certainly not a web designer
- - - edit - - -
#28
hi new to the forum
Im wanting to be different and supercharge my 88, but i want to bore the vg30 30 over so it becomes a 3.3L. But i had another idea, the xterra has a supercharged 3.3L from the factory right? so can i take that motor and bor it to a 3.6L and beef it up with a bigger supercharger. Im looking to make it a show/street car with roughly 600-650hp.
#29
You have a LOT of reading to do if your asking questions like this and want that much power. You will pretty much need a built motor with ALOT of custom work, even more so with a supercharger.
#30
