Vaccum Leaks...84N/A
Re: Vaccum Leaks...84N/A
it's probably one of (or all) of the hoses going to the servo behind the pass side headlight. check for cracks at the ends of the hose and see what you find. One of them goes thru the firewall and down to a T connection under the glovebox and kinda toward the center of the car. remove the panel under the glovebox and look up under there (with a flashlight) and you'll find them.
Since all your hoses are probably just as old as your car, take a coupla snips from the ones on your car (leave enough to reattach them to where they went so you can drive it though) and get new hoses from your local parts place. I used to start with about 30' of the smallest size and 15' of the next size up then just get more as i needed it. Nowadays though I just buy the stuff by the spool (50')- it's useful for all sorts of stuff, and it's cheep. I've got several z's so I know it'll get used eventually.
