1987 300zx non-turbo steering box problem
I'm working on restoring my 87 300zx
my steering colum is fine and my rack and pinion bar seems to be in good shape, but the wheels will not turn or even budge when i turn the wheel. Even with the streering colum unlatched from the steering box, i still can't turn the tires by hand.
I am assuming that there's a problem with the box.
Does anyone know how to remove this part so i can look at it, or replace it; or if you know of a solution for the problem, can you help me out?
Not to insult your intelligence but did you turn the key to unlock the steering column?
You say you can't turn the wheels by hand. Are the tires in contact with the ground?
I'm not sure what you mean by steering box. The rack is pretty much all one unit. You can get a rebuild kit but it's best to just buy a new rack. Have you checked the steering knuckles and tie rod ends? I've been driving z31's for almost 10 years and earlier z models before that and I've never seen this. In the pic below, is the part just below the u-joint what you mean by steering box?
its lifted off the ground on my jack stands
steering column in unlocked
my apologies...the steering box is - like you said - one unit, the rack and pinion, i know that
i need to replace the passenger side tie rod anyway - would it be best and easiest to just buy a new rack and pinion with two tie rod ends and replace its all?
This might come in handy.
Now playing: Dada - Dizz Knee Land
via FoxyTunes
wow, thanks, that'll help out a ton
i'll save this and look it over tonight, i finally got it up on jack stands last night, so this weekend i'll look it over and see what i can come up with
im pretty sure i just need to replace the whole rack and pinion bar AND tie rod ends
when i got it the passenger side tie rod end was broke in the middle - so i had a buddy get a two piece pipe around it and welded it together just to hold it so i can tow it till i replace that
i haven't driven on it, and won't drive on it, till i atleast get that tie rod end replaced
lol, no im in florida - and the tie rod is broken from the previous owner towning it himself to my house - the tow rope wasn't put on the tow loops - just around the rack and pinion - and when it was stopped it shifted to the side by the tire and when he hit the gas to go - the rope just snapped the tie rod
i haven't had time to take off the rack and pinion, but someone on another forum told me that if it has been messed with or tried to fix or somethin before - its very possible that dirt, water, and just crap could get into the steering box of the rack and pinion and gunk it up so the steering won't work at all - so im just going to buy a new one with two tie rod ends for about 140 i found online still in the box, that will replace the whole steering problem and that way i can move on to the little stuff i need to get done to it
i i got some pics up in my album on here if you wanna see it now - i'll get more of the part to show you as well, and i'll keep it updated when i get somethin done
