86 z31 turbo with boost problem :(
I just had my 3" exhaust done an a 2.5" intercooler but i notice dat i wasnt boosting my gauge read 0 lbs an if i shift into higher gear an floor it the boost will go up to 4lbs an then start droppin till it hits 0 again i did a leak test on the intercooler setup an it hold more than 20lbs without a leak any suggestions on what the problem maybe thank you for all the help.
All the hoses are tight as they could be an i did a leak test and it hold the air well without a leak an im not running a boost controller just stock boost could it be the wastegate actuator
It sounds like you know what you are doing or you wouldn't have added a intercooler.
Makes me wonder if something got sucked into the turbo? You had a lot of new parts that could have had something in them. Packaging peanuts, tape, paper etc. Maybe something soft enough to only drag the turbine down but not stop it.
I removed the coupler that conect to the throtle body an plugg it with a pvc drain pipe an on the side of tHe turbo another plug with a gauge to measure air presure an i put 20lbs an checked all couplers with soap an no leaks at all i let the air sit for about 5 mins an only about 2lbs dropped
Wastegate replaced an still no luck the only bad thing i could think of but dont knoe if its whats causin my problem is an exhaust leak on the left side manifold the gasket is out an it leaks alot i will change it but i was wondering if dat had anything to do with my problem thank you
Did you replace the Wastegate itself, or just the wastegate Actuator ? (or both)
