88 turbo manual trans into an 86 turbo
Old 09-13-2007 | 09:08 PM
Turbo86's Avatar
if I swap an 88 turbo trans into an 86 turbo what all do I need for the swap
250mm clutch? (86 has a 240mm right?)
88 driveshaft? (or will an 86 driveshaft mate up)
do I need to drill some new mounting holes?
Old 09-14-2007 | 12:42 AM
AZ-ZBum's Avatar
clutch goes with the flywheel. if you keep the same flywheel, you don't change the clutch.
yes. you'll need the 87-89 turbo driveshaft.
probably.
Old 09-14-2007 | 08:09 PM
johnZboy's Avatar
Distinquished Guest
You can "upgrade" to a bigger flywheel and clutch with the '88 tranny, but, that is optional.
Get the driveshaft that matches the tranny. The splines are different. I suppose you could change front yokes, but, why. Just use the complete '88 shaft.
I didn't have to drill any holes. Nothing wanted to line up perfect, or easy, but all the bolts went into the holes as they were intended.
Old 09-15-2007 | 09:22 AM
Turbo86's Avatar
any advantage or disadvantage to 250mm clutch/flywheel over a 240mm clutch/flywheel
Old 09-15-2007 | 01:05 PM
AZ-ZBum's Avatar
not really.
MrDad1
09-30-2012 03:39 PM
Z_Rac3r
04-06-2009 09:13 PM
millerlife
05-14-2007 05:15 AM
slow'n'steady
52
06-14-2006 03:38 PM
RunninOnEmpty
08-27-2003 10:35 PM
