am i missing something
okay
im replacing the headgasket in my z31, and im almost to the heads, but my exhaust is pissing me off, how the heck am i suppose to get to some of the bolts? im primarly talking about one that is so close to the firewall i can only get a socket on and not a wrench
any suggestions?
any suggestions?
Originally Posted by drkfilldschemis
okay
im replacing the headgasket in my z31, and im almost 2 the heads, but my exhaust is pissing me off, how the heck am i suppose 2 get 2 some of the bolts? im primarly talking about one that is so close 2 the firewall i can only get a socket on and not a wrench
any suggestions?
any suggestions?
yeah ur a lot of help
thanks,
moderator.
oh snap...... no he didnt just say that to E, hey.... E's mine im the only one around here that makes fun.
but he said it in good menaing. if you start using the number instead of the word...people are gonna get F'ing confused fast. and then take even longer to help you
LMAO i cant believe you spelled out the number one though...
okay
any suggestions?
any suggestions?
Unless by wrench you mean the socket wrench itself. But if you can get a socket on them, then you can get an open ended wrench on them.
But in all honesty, I left the exhaust alone and detached the manifolds from the heads and let everything just hang in there. Expect to break a stud or two. And while you have the heads out, replace them with NEW grade 8 bolts.
yeah i meant the ratchet wont fit in there, but the socket will, its to close of a fit, and i tried a wrench and it started to strip it
hey i got a question, is that pully and bracket next to the cover bolted to it along with the head?
yeah i meant the ratchet wont fit in there, but the socket will, its to close of a fit, and i tried a wrench and it started 2 strip it
hey i got a question, is that pully and bracket next to the cover bolted 2 it along with the head?
am i missing sumthing
im replacing my head gasket
and i took off the valve cover and all that stuff
and took out the cylinder head bolts
and unbolted my exhaust
but i still can't get it off to get to my heads
is there sumthing im missing
such as a bolt or anything?
