any recalls on the z31?
okay ur probably all getting sick of my endless questions...
are there any recalls on an 86 300? in the last three days my brakes went out, the power steering went out, and im broke as hell!
hi mate im james i got an 86 z31
if like me you have a car that looks the goods and you got it cheap.
your going 2 have problems. see mine has a custom paint job 17"mags 3" exhaust. dual stage boost controller front mount intercooler mp3 wma deck and mental alarm with remote start.
all that and i only paid $4500 with rego.
then came the problems. they drove the car 2 us we drove it once and the clutch was f@cked so i fixed it.
then a mental boost cut then an idle problem.
the diff is still on it's way out (not my fault slightly stuffed 2 begine with then tha button clutch killed it sum more) then we had the hose between the injector rails crack and 2 get 2 that off came the manifold.
*** please check that your rocker covers are tight as if there not or the gasket is stuffed it may leak as mine did at the back down the engine and into the clutch. f@ck's them almost instantly. later bro.
so yer it all depends on how its been treated...
