anybody run no exhaust ... only turbo elbow?
anybody run no exhaust ... only turbo elbow? ... how many fires will I start? ... and how many noise tickets will I get? ... I can't get the damn broken bolts out of the turbo elbow ... I've tried a torch, easy-outs, drill bits, locking pliers, pb-blaster, dremel tool. ... I'm about to get medevil on it.
I had that prob on my 280zx turbo downpipe. I had a buddy w/ a "rosebud" tip & worked wonders. About 10 minutes on each bolt, and they backed right out. So find yourself a rosebud tip for the oxy-acetylene torch & you'll be rockin!
dremel tool " cutting disk " item number 420 use that to cut off wheel then when u cut it off step by step drill bits worked for me.. after u get to the right size 1/2 inch for me.. TAPE AND DYE SET worked for me for my 83 280zx down pipe..
does the torch have to be oxy-acetylene ... can a lesser torch work like a plumbing micro torch or does it not have enough heat power ... my dremel burst into flames last week in my hands it was a cool site though ... I was putting too much strain on it cutting thru exhaust pipe ... I got an angle grinder now ... I need to get another dremel they do come in handy
Originally Posted by wreckedj30
hmm, why don't you just weld a straight pipe up, that way it will be less loud inside yet still, hella loud.
Right now, i just am running to a cat, well thats for now...nismo.
couldn't you just cut off the bottom of the downpipe and weld there. or naww. and the *** that told me he could get exahust is just that...a lazy ***, so i'm stuck for know..and a healthy bill is find if its just a bill. cause i'll still need gas money to get home.
Spyder Z 15
08-20-2008 12:28 PM
