Bleeding Clutch Write Up/Walkthrough!!!!!!!
Old 02-23-2006 | 08:32 PM
numb1300z's Avatar
Since I got the master/slave cilynder problem down I just nood to know how 2 properly bleed the clutch system. I have a 86n/a.
Old 02-23-2006 | 08:55 PM
jfairladyz's Avatar
It's just like bleeding your brakes except instead of having to bleed 4 calipers you only have to bleed one slave cylinder. If you've never bled brakes before then I dont know what to tell ya other than google. Just type in "how to bleed the clutch" and I guarantee you'll get hundereds of articles on how to get it done. But for a quick and simple run down you simply need to pressurize the master cylinder (pumping the clutch pedal) and then release the pressurized air and fluid through the bleeder at the slave cylinder. Just repeat the process until you've gotten all the air out of the system. A better alternative is to use a vacuum pump to suck the air and fluid out of the system but the choice is yours.
Old 02-24-2006 | 04:12 AM
entropy31's Avatar
The Cake Is A Lie!
buy a haynes manual. click here
Atomzzz
01-11-2014 03:30 PM
raythenegr0
11-16-2007 11:18 AM
280zx81
04-06-2006 10:38 PM
Skully
06-05-2003 08:28 PM
ratedZ
06-06-2001 10:40 PM
Quick Reply: Bleeding Clutch Write Up/Walkthrough!!!!!!!
