Boost controler
Boost controler
Hey guys sorry if im getting annoying but i am buying a manual boost controler and I was wondering where in the heck to put it cuz I have no idea. I know I can't run more than 11 psi on a stock motor but that is ok with me its more power to wheels as i see it. I also like the fact that I don't need to run the rull 7.5 the whole time I can cut it down and save gas! I got the boost gauge working and set to go.
Lets turn up the boost now!
Google works wonders!
http://www.well.com/~mosk/boost.htm
EDIT... Not to dig up the past, but weren't you the one that said you knew about turbos? https://www.zdriver.com/forums/showt...583#post121583
Yea I do know turbos on other cars but I have never worked on a turbo 300zx before being as this is my first. I have been very busy working 2 full time jobs so its been awhile since i actully got to work on a car!
Originally Posted by machsound
please explain!
Do you have a Haynes/Chilton manual?
I know what it does I just don't know how to set it! I do have an old haynes. Does it have all of that stuff in there how to set it and what not or is it just in there how to remove it. I would really like to keep it incase something goes wrong when running a higher boost, once i get the intercooler on it. My bros tsi never had one we just pulled off a vac line and it would run like 19 psi (bad for engine) but fast as ****.
meh not really, my buddy has an all stock internals engine, everything else is chagned turbo fule ECU cams etc.
If you changed all of that in the vg30 then you could run 20 psi also the only thing keeping us from running over a bar is fuel (and of course and intercooler) but anyway does anyone know how to set a pov thats the question?
Alright I figured out how to change the pressure and ummmm well the pop-off is just going to go. I've got a boost gauge in there so it really won't matter if I start to spike i will notice it. Im also getting a air/fuel gauge so its going help also. Now i just have to locate the damn thing!
Lotek (gaugepods.com) has a three gauge piller pod available for our cars. That way you can put a decent vac/boost, A/F ratio, and what ever else gauge you want to run.
Why would I do that and my car look like a honda I am just replacing the factory gauges in the two spots to the side (accelameter and compass) the compass is already gone and i just need to get the a/f gauge. I Don't need all that ricey crap!
ummmmm yes in my oppinon they look like crap and if you own a car like that you should have a little bit more money to make a custom dash to fit them in where they are easyer to see anyway. Just my opion! I don't like them.
Like i said i pulled out the useless gauges in the two spots there and put the boost gauge in already and am waiting for the a/f gauge to get here to put it in.
Im not trying to fight with anyone on here its pointless if you like go ahead and do it. I just think it looks like crap and very cheap looking. There arn't any other gauge's that i would need so the third gauge pod would be for what a clock! I don't think so.
Boost controller installation: goes on the vacum line from the wastegate accuator.
POV. ON the intake manifold Plenuim. Just take it off. Get a plug from a NA model and install it. Your going to want to get a BOV of somesort to save your stock turbo a bit. I know stock 300zx's came w/ a recirculating valve but you can bypass that and run a straight bov. The recirculating valve is okay for stock but does not release quick enough for over boosted situations...
as for the lack of an intercooler.. have you thought of water injection?
Gauge Pods. Whats so rice about them? Rice are the people who get the carbon fiber gauge pods put a boost gauge in it for their NA cars and all the gauges light up blue. If you need to see whats going on with your engine then whats the big deal.. What type of A/F meter are you going to be running.. i sure hope you plan on going w/ a WideBand of some sort esp if your going to be boosting up.. Plus you may want to have a little bit more accurate gauges such as a aftermarket oil pressure gauge, water temp, and oil temp gauge oh there is there gauges right there.. thats a full pod... so if you think those are useless..how much do you want for your car after you blow a head gasket?
Shameless
14
01-12-2006 02:37 PM
jtmny1999
04-03-2003 08:40 PM
