Breaking loose o2 sensor
Old 12-27-2005 | 08:30 PM
Ravin's Avatar
Angry Breaking loose o2 sensor
I am trying to replace the o2 sensor in my 84 turbo Z. I am having trouble breaking the thing loose. Is there an easy way to get the thing out? I tried using a deep socket with an extension but it wouldn't budge.
Any suggestions would help. If it comes down to it I'll pull the damn exhaust manifold but I would really rather not.
Old 12-27-2005 | 08:33 PM
use some good penetrating oil like Deep Creep or PB spray. Don't use the shibby "WD40" That's like water!
Old 12-27-2005 | 11:34 PM
CanyonCarver's Avatar
Jack Of All Trades
They'll come loose alot easier if you get the motor up to operating temp. Then spray on your penetrating oil. The heat causes the metal to expand.
Old 12-29-2005 | 12:04 AM
WhtFairLadyZ's Avatar
i know on my TT when I putting Down pipes on..i used a butane torch to heat the metal bung up to get the metal to expand. I was afraid of damaging the O2 by using a big 'ole pry bar.
Old 12-31-2005 | 03:58 AM
ZenArcher's Avatar
Soak with PB Blaster, Aerokroil, or something like. Use 1/2" drive ratchet and extensions and a breaker bar because 3/8" tools will likely break.
Old 01-01-2006 | 02:41 PM
Ravin's Avatar
Thanks for all the suggestions, I didn't think to heat the area. However, after using PB Blaster, a pipe and a hammer, I broke the old one in half. After that what was left on there came right off with a socket extensions and rachet.
Car runs much better with new O2 sensor in.
Old 01-11-2006 | 03:22 PM
WolfMan's Avatar
Good thing you did not heat it up though, you could have broke it.
Old 01-11-2006 | 03:25 PM
he he! oh... wait a minute....
77'two_eighty
06-22-2007 09:36 PM
BlackCrow
07-26-2006 11:14 AM
HybridS130
06-19-2006 02:49 PM
Fast240Z
10-27-2005 11:44 PM
CanyonCarver
09-01-2004 04:31 PM
