Car stalls when warms up (97 turbo)
Old 11-18-2012 | 09:44 AM
chappo123's Avatar
Car stalls when warms up (87 turbo)
Still trying to get to the bottom of this problem, lots of advice and experience picked up from this and other forums. Previous owner has already replaced the CHTS x 2, air regulator, fuel filter, fuel pressure regulator, oil pressure sender, dist cap and rotor.
I have been working around the connectors and all so far look clean. Some vacuum pipes have been removed - those to the carbon cannister - which has also been removed. No EGR - is this just a US spec sensor?
Checked the MAF this morning, disconnected it with no difference noted. Positive in that ECU picked up it wasn't working when disconnected.
The ECU changed between 1986/87 models. Does anyone know if they are interchangeable? Looking at differences in the list of error codes, I suspect I have a 86 in my 87 car? Is there anyway of checking the serial number or are there any physical differences?
One thing for to get a mechanic in to look at is the return fuel pipe - understand that a blockage can cause a pressure build up and a stall result?
Any other advice welcome.
Matt Hidy
07-27-2015 06:54 PM
jmotley
12-12-2013 08:05 PM
dankfrye@charte
11-08-2011 07:59 PM
scorpionp54
01-06-2008 09:26 PM
chinesekid
04-10-2006 09:51 AM
Quick Reply: Car stalls when warms up (97 turbo)
