Clunking noise in rear end when shifting
I have a 1986 300ZX NA with the five speed transmission. When driving the vehicle if I release the clutch quickly (as in any stick I've driven) the rear end clunks, if I baby the clutch the noise isn't there. I thought it could be one of many things so far I've decided it could be:
- The subframe bushing
- The rear struts
- Transmission mounts
- Or rear axle
Z-31 rear clunk
- The rear struts
- Or rear axle
what would be easiest way to check the diff i have some play with car up and spinning the wheels maybe 1/2 inch or so when spinning one wheel before the other starts to spin also but i figured that it would be a warn cv axel even though the boots are intact
Just take a look at the rubber bushing/mount on the rear of the diff where it attaches to the car, that's what usually goes bad and causes a clunk.
by both wheels turning i meant that on jack stands in gear they bot turn and the have some play and is it possible that someone could post a picture of what the diff mounts are supposed to look like cause i throughly believe mine are more than likely the cause
also does anyone else have issues with the site working on a mobile
The most common source of the clunk (IMO) is the subframe bushings. If you can grab stuff and it doesn't move, then that really points to those. Diff mount is simple to remove and reinstall if it's okay.
Yeah, I'd say worn out differential mounts. Nissan still sells them, I think, calls them 'insulators.' $45+? Aftermarket is cheaper and OK too. Easy to check out if you lift the rear end and look behind the rear wheel. The hard rubber cylinder inside the ring gets chewed up over time. If the clunk is more of a loud click, could be drive shaft uni joint. Can get a new drive shaft around here for about $120. Nissan wanted $600 for it! :-(
Hpjc10
10-28-2013 09:03 AM
