Compression test
Compression test
CYL#1 -111
CYL#2 -105
CYL#3 -104
CYL#4 -111
CYL#5 -138
CYL#6 -103
Looks like Cylinder 5 took a crap, I pulled the spark plug and it had coolant and oil on it. Looks like head gasket job, any suggestions on the easiest way to get the job done?
CYL#2 -105
CYL#3 -104
CYL#4 -111
CYL#5 -138
CYL#6 -103
Umm... Higher numbers is better. Looks like you're low across the board EXCEPT for cylinder #5. I think your rings are very worn out if all your numbers are that low. Looks like it's more than a head gasket. Looks like it's a full rebuild.
If he found coolant and oil on the plug with the highest reading I think the coolant and oil sealed the rings more then usual which gave the higher reading. I would say check the head gaskets first, worst comes to worst he's already a step ahead if he decides to rebuild the motor.
