Driveshaft?
Old 06-21-2005 | 04:19 PM
UltimateZ's Avatar
Driveshaft?
Can someone help me, im trying to figure out how I go about changing out the driveshaft on an 86 300zx non-turbo. What do I have to remove to get the driveshaft out?
Old 06-21-2005 | 05:30 PM
Fast240Z's Avatar
it's pretty simple. Jack the car up (safely), crawl under it, and unbolt the driveshaft from the differential (near the rear of the car). This should have a number of bolts that hold it to the differential. After unbolting that, pull the rear of the driveshaft down (push forward towards the transmission and it should come down), then pull the driveshaft out of the transmission.
Old 06-22-2005 | 11:45 AM
mark86t's Avatar
Make sure the car is higher in the rear than the front so transmission fluid does not come out when you remove the driveshaft.
Old 06-23-2005 | 01:37 PM
UltimateZ's Avatar
But dont I have to remove the exhaust pipes or anything like that? Can I do it without removing the exhaust?
Old 06-23-2005 | 01:42 PM
Fast240Z's Avatar
you should be able to.
burble_boy
01-19-2021 08:52 AM
kevtt
03-10-2006 06:55 PM
XGames415
02-05-2006 02:18 PM
domsgarage
12-04-2004 07:03 AM
domsgarage
19
01-31-2004 09:54 PM
