The fan behind the head light only turns on when the key is all the way off.
The fan behind the head light only turns on when the key is all the way off. If you put the key in any other position it turns off...I have to unplug it to make it turn off, and i won't turn on at all when the car is on. could it be a reversed wire or something simple hope fully?
Is your motor getting hot (temp gauge going over half way)? I'm sure the Z31 injector fan is programmed in a similar way to the 280zx... if the coolant gets above something like ~220* at any time when the motor is running, once the car is turned off, the injector fan will come on for 17 minutes.
ricky0288
05-27-2011 11:07 PM
nka04a
03-18-2005 05:00 PM
