Heads
Old 02-25-2008 | 04:15 AM
84z31nonturbo's Avatar
Heads
This may be a simple question but, can I put heads from an 85 vg30et onto an 84 vg30e? Obviously they will bolt on but are the valve lengths the same and everything? From what I have read everything will work just fine, but I am just not positive.
Old 02-25-2008 | 10:00 AM
turboZ87.300's Avatar
If I remember right, the only thing that was changed was the pistons. You might check on the cams...
Old 02-25-2008 | 12:09 PM
xenonxiii's Avatar
Heads from 84 to Early 87 are the same. From late 87 to 89 are the same
What you got will work fine.
Old 02-25-2008 | 02:17 PM
why does everyone assume that just because its turbo the heads are different?
Old 02-26-2008 | 06:52 AM
I was assuming the were different because I know the vg30et has lower compression (shorter pistons). I was not sure if the valves in the vg30et heads were longer, I didn't want to put turbo heads on my non turbo engine and have the valves hit the pistons. But I thank everyone for their input, and information.
Old 02-26-2008 | 01:38 PM
it doesnt have shorter pistons, it has dished pistons, which lower the compression.
Old 02-26-2008 | 07:19 PM
Didnt know that. Thanks for the info.
Old 02-27-2008 | 12:30 AM
its the same thing for all zcars except for the 83 280zx, the turbo cars had hydraulic lifters
KasbeKZ
10-19-2007 12:42 PM
ThermalWake
04-20-2007 11:38 PM
flightforlife07
09-23-2005 09:03 PM
tt300z
FS: 300ZX (90-96)
05-02-2005 07:07 PM
Denver93TT
03-21-2005 08:52 PM
Quick Reply: Heads
