HELP! new z owner , motor question
Old 02-16-2013 | 11:17 AM
84nissan300's Avatar
Exclamation HELP! new z owner , motor question
I recently bought 84 300zx and the last owner put a new motor in it but didn't finish hooking it up , from my research I've figured out the body is a non turbo body, but from just looking at pictures on Google the motor looks to me to be a vg30et motor?? how can I tell for sure ? is there something on the motor I can look at or what ?
Attached Thumbnails HELP! new z owner , motor question-motor.jpg   HELP! new z owner , motor question-car-body.jpg
Old 02-16-2013 | 01:23 PM
ThaPimpShrimp's Avatar
Well.. does it have a turbocharger attached to it? That would be one way to tell..
Old 02-16-2013 | 03:24 PM
rogerz's Avatar
Grumpy & Helpful
with that picture the motor is a vg30e?. if you have a tubo charger it is buried down low on the driver side. follow the intake piping from the maf to where it goes. you will find a turbo charger or just goes to the throttle body.
Old 02-18-2013 | 02:38 PM
thanks , I looked and no turbo unfortunately . it goes straight to the throttle body. Now I just have to figure out why i'm not getting spark to the coil.
Old 02-18-2013 | 05:30 PM
rogerz's Avatar
Grumpy & Helpful
spark comes from the coil not goes to it. Crank angle sensor or ecu two possibility. BAd coil or bad igniter. you getting power to it?
Old 02-21-2013 | 07:59 PM
i'm not much of a mechanic , so sorry if my lingo is off. This is kinda my project to learn on . and I checked and no power is going to the coil and the coil fuse inside the driver side kick panel and its not blown .
Old 02-21-2013 | 08:49 PM
rogerz's Avatar
Grumpy & Helpful
you need to study some electrics. the ecu bumps the igniter (power transistor). that bumps the coil when the magnetic field of the primary collapses it generates 10-20 KV which is what makes spark. read the fsm free download at xenon if you don't have it. it used to be done with points (when I was a boy and dinosaurs roamed the earth.) maybe read up on that.
Old 02-22-2013 | 11:56 AM
I have a haynes book that I've been using to try to figure out what to look at next and xenon site has helped quite a bit too. I checked if the power transistor is getting power to it and it is , but its not getting to the coil . Is there a way to check if the transistor is bad so its not putting power back out ?
Old 02-23-2013 | 12:07 PM
Exclamation power to transistor but not to coil????
I'm having a spark problem and through checking wires with a test light , i've figured out im getting power to the power transistor but its not making it to the coil . power transistor bad maybe?? is there any way to check it ?
z31dan
09-05-2013 02:08 PM
mobcharge
09-23-2012 12:31 AM
btopanama
05-28-2005 07:39 PM
AnTman86Tn82ZX
03-07-2004 05:12 AM
hawaii2z
09-13-2003 12:38 AM
