Hole In Firewall
Old 03-02-2009 | 07:55 PM
ZThirtyOne's Avatar
Hole In Firewall
Does anyone know the most convenient spot in which to run a power cable through the firewall. Its always a hassle in a new car locating an spot that can easily fit a larger power cable for an amp. Thanks Guys
Old 03-02-2009 | 10:47 PM
just take an already existing gromet and make it fit, it SHOULD work, if theres no space then just make a hole and gromet setup where you feel is most appropriate and will work, or ghetto it and run it through the fender. your call
Old 03-03-2009 | 05:37 AM
User395's Avatar
Is the car manual or auto? If it is auto you can run it through where the clutch would have been.
Good luck!
Old 03-15-2009 | 06:48 PM
SloppyGoat's Avatar
I ran mine through the grommet on the passenger side. I think it was the one behind the air system. I remember I had to remove a bracket on that to get to it.
PCressey
04-01-2015 08:40 AM
beg3yrs
01-06-2015 01:33 PM
hoov100
11-18-2008 12:37 PM
xeon
08-30-2001 10:07 AM
xeon
08-30-2001 08:00 AM
Quick Reply: Hole In Firewall
