how to handle
Old 07-11-2007 | 03:03 PM
drkfilldschemis's Avatar
how to handle
okay here's my problem, ihave 85 non turbo z31, and it wont start
so 2day when i tired to start it i sprayed starting fluid in it and it does more and acts almost as if it wants to start but can't hold it or something
question im needing answered is what do i start to look at next cuz my car does that, what can i fix to solve the problem and have my car start fine?
Old 07-11-2007 | 03:08 PM
Is this the same car that you were talking about in this older thread? https://www.zdriver.com/forums/300zx-z31-performance-technical-227/car-wont-start-20334/
When an engine doesn't start, it's only 3 things:
#1... improper fuel mix (no fuel, or flooded)
#2... no spark
#3... no air getting to the intake / combustion chamber.
Have you checked these three things?
Old 07-11-2007 | 03:14 PM
i no there is air getting into the in take
i bought new spark plugs,
and i can hear the fuel pump on the back of the car, so anyone think it could be fuel injectors? or does a bad fuel filter sound more like it?
Old 07-11-2007 | 03:18 PM
Spark plugs are at the end of the line... just because they are new doesn't mean they have to spark. The coil creates the electrical current, sends it to the distrib, which distributes the spark to each wire, then to the plug. See what I'm getting at? Check upline for spark...
Old 07-11-2007 | 04:20 PM
okay gotcha, also like i said with the ligheter fluid it'll start the car for just a split second, so doesn't that mean fuel is the problem? if so what kinda fuel problem could it be? fuel pump or could it even be the injectors?
Old 07-11-2007 | 04:26 PM
entropy31's Avatar
The Cake Is A Lie!
it could be any kind of fuel problem, or not a fuel problem at all. test things, see what works. it's called troubleshooting. replace the filter, pull some hoses and see if they squirt fuel, test your injectors, etc etc etc. we cant check these things for you through the internet. it does sound like you may not be getting fuel, but many things can cause that.
Old 07-12-2007 | 01:36 PM
PooFlinginMonke's Avatar
Broken timing belt.
Old 07-12-2007 | 08:54 PM
okay when i replace the fuel pump,filter,and injectors here soon, if that doesn't make it start then where else should i look?
or what else wouldn't hurt to replace quick while im replacing stuff?
Old 07-12-2007 | 09:35 PM
z-hag's Avatar
Queen of Yachts
my 1986 turbo woulfd have same problem 2 days after it rains........was the water coming into the car via the windscreen gasket and getting into the ecu............check it out .............
Old 07-14-2007 | 05:04 PM
so ur saying the ecu might be corrupt?
also i have a question, when i try to start the car i hear the fuel pump in back make noise the whole time, is that suppose to be like that, or is that a sign saying the fuel pump is bad or something? i have no clue here so any help you guys have really helps me, thank you
Old 07-14-2007 | 05:18 PM
She means that water & ecu's don't mix.
That's a good sign... if you DON'T hear the pump, that's a prob.
Old 07-14-2007 | 05:35 PM
well i just hear something from the back the WHOLE time like a whinning sound or something along those lines. In your guys personal opnion what would u replace first or think it is? the pump or injectors?
Old 07-14-2007 | 06:03 PM
Don't replace anything until you know what the problem is. Unless you like wasting money.
Have you checked your fuel pressure? If the fuel pressure is good, more than likely your injectors aren't spraying either because they are clogged, or a sensor not working right.
Old 07-14-2007 | 06:08 PM
how do i check fuel pressure again?
Old 07-14-2007 | 06:14 PM
Get a fuel pressure gauge & hook it up after the fuel filter & before the fuel pressure regulator. If the Z31 has a fuel check / relief valve, you should be able to hook it up there w/ the right adapter.
You have a Haynes or FSM right???
Old 07-14-2007 | 06:44 PM
yeah i have a haynes manual,i knew how to do that,i was just wondering if there was another way to do that, that you would suggest
Old 07-14-2007 | 10:16 PM
z-hag's Avatar
Queen of Yachts
only other way i know is to pay a whole lot of money to as mechanix shop and have them still not find the problem.................
Old 07-15-2007 | 08:29 AM
okay, thanks for everyones help if i have any other questions or if you guys have any other comments i'd love to hear them,
thanks again
Old 07-16-2007 | 07:56 PM
oh hey just a little update, i replaced the fuel filter, and put in injector cleaner, and a new battery cause the old one was drained, then i put the new battery in and it starts making crazy noises and then smoke starts coming from the BRAND NEW battery just bought 30 mins earlier, now im just trying to decide what to do now
Old 07-16-2007 | 08:45 PM
i also have another thing to add, my friend wants me to put in a supra engine, or a skyline engine, but i dont know if its worth it.
i wanan put a new engine in it---a really really good one---but i dont really now whats worth it, would it be smarter to rebuild one of those and put it in or rebuild a vg30de, or vg30dett
Old 07-16-2007 | 08:55 PM
entropy31's Avatar
The Cake Is A Lie!
i would not suggest a VG30DE or DETT. just get a VG30ET. you can get plenty of power from one for less money than any other swap would cost.
Old 07-18-2007 | 06:00 AM
Z Car Barbie's Avatar
User Friendly
Your problem can be one or more of many. I would first run the ECU codes and see what errors appear, if any.
If there's no error codes, then we can diagnose from there. It'd help if we knew the history on this car (the mileage, how long you've owned it, what you've replaced since, and what was replaced before you bought it, if you have the receipts or information).
Old 07-20-2007 | 01:45 PM
Battery in backwards?
Engloid
02-21-2014 09:24 PM
ol55
11-29-2013 08:08 PM
Turbo86
04-25-2006 04:09 PM
n_2_fairladyz
06-07-2003 07:00 PM
XXtacy
11-24-2002 12:06 AM
