i want 300hp
i want 300hp
i have a 86 na and i want to go turbo and keep my block how much boost can i do stock and if i add a new intake manifold from a 93 pathfinder and throtle body fom a 92 240sx im so confused need help :headspin:
eh I wouldnt run more then 5 pounds on stock compression. That would put you about 215-220HP. After that your going to need to lower your compression, other wise 300HP isnt going to be reliable with stock compression under boost.
I was going to put a intake manifold from a pathfinder on it for beter air flow I dont know if it increses the compresion does any on know? I was also wanting to run 6 - 12 pounds boost with a vary good ic. I can get a good turbo kit for a grand :roflmao:
Originally Posted by Z32TTgirl
Redbeauty84ZX nailed it on the head.
About that "turbo kit", you might want to make sure that is a 1984-1987 z31 turbo, especially if you plan to install it yourself. Otherwise you're going to need some good fab skills. Might be better to get a z31 turbo parts car and take what you need from it. Or just sell your car and buy a turbo z31. The Pathy intake is a good idea but that's a project and you'll need some fab skills for that too. It won't increase your compression.
280zx_82bizox
07-11-2005 09:33 PM
