manual transmission
Re: manual transmission
if you get the kind that comes in a bottle with a pointed nozzle, then you can force the long tube onto it and squeeze the oil into the tube and down into the tranny. they also make these fillers that are a tube with a fitting on the end that you screw onto the bottle you are filling. the tube is only about 16" long though, I replaced that tube with a longer one and filled it from the top of the engine. That seemed to work pretty well. the fitting fit's the bottle tight enough that you can squeeze the bottle, otherwise it would take all day for it to fill the tranny.
74260zt
02-23-2008 07:30 PM
