Oil feed for turbo leaking at banjo bolt
Hey guys I just motor swapped my z31 since the old motor was blown. We used two crush washers for the banjo bolt for the oil feed for the turbo but it seems to leak for what ever reason. Its leaking on the crush washer that is in contact with the block. Any input is helpful, thanks!
I suppose there are a couple of reasons for a leak.
- Did you use new washers or reuse.
- Was either surface damaged? Even a small radial scratch can drive a leak
- Foreign material on either surface.
- Sometimes a strain on the connection could cause a leak. Did the banjo fit up easily with no effort or did it have to be forced on. Is there anything external putting stress on the connection.
