is a rising rate fuel reg. a good mod?
Queen of Yachts
i found thatmods slowed down my AE and made the car perform poorly, so removed the k+n filter and the other aftermarket stuff and now my car is poifekt.....is yer fuel pump not working????? or are you just not going fast enough.........???????..
RR FPR's are designed to work on forced induction engines. For every lb of boost, the fpr raises the fuel pressure by 1, 6, 8, 12psi (or whatever the spec). Using it on an n/a motor is pointless.
As for you: unless you are running out of fuel @ full boost (usually above 12psi on a stock Z31T), you don't need to use one, nor would you benefit much from it.
byrneZ
01-09-2008 10:12 PM
hellzbellz83t
04-05-2002 11:28 PM
