temp gauge
temp gauge
i just got an aftermarket water temp gauge and am wondering where it screws in at. i am all so wondering if that would give me the same readings as the stock one. i have the didgital dash and nothing works so i just want to know if im gona over heat
Most cars have the sensor at the thermostat neck since that's the hottest point for coolant. You could probably retrofit your new sensor into the stock location.
And what brand water temp gauge did you get? Cheap ones are, well... cheap for a reason.
You can also test accuracy by using a non-contact infrared thermometer...
300zx, adaptor, aftermarket, gauge, guage, installing, pics, place, temp, temperature, turbo, water, z31
