Timing Belt Question
My chiltons manual says I have to loosen the rocker shafts to achieve the correct tension on the timing belt when intalling it. I was just wondering, is this a must? If so, is it possible to take the driver side valve cover off without removing the intake plenum?
the nissan shop manual also says to loosen rocker shaft bolts to be able to adjust tension correctly on timing belt. yes you should be able to get valve covers off with out removing intake plenum, but you will have to remove everything from the air filter up to the throttle body, in order to get the bottom belt cover off you will have to remove the crankshaft pulley. good luck.
Is the timing belt tensioner self adjusting?
Muzzletones
02-09-2015 10:46 AM
