turbo timer
turbo timer
I installalled a turbo timer today but I can still shut my car off the turbo timer is an apexi I was just wonderin if anyone has any detailed pics of the three wires I need,to tap in the ignition harness
Searchy and ye shall findy.
https://www.zdriver.com/forum/300zx-...o-timer-28340/
This thing is stupid easy to wire up. All 3 prong turbo timers are basically the same I found out. At least HKS and Apexi are... from what I read.
You have to dig a little to find the wiring for the ignition. Just un-plug the connector and pull it out to get some slack.
3 main wires
Red wire = 12v constant---red with red stripe in car
Blue wire = 12v accessory---blue wire in car (not 100%, I forgot. lol)
Green wire = 12v ignition---black with white stripe in car
2 individual wires
Gray wire = parking brake wire
Black wire= ground
Splice that **** into the ignition wire harness, and you're golden. I had about 45 min into wiring the thing up and mounting it. And figuring out what wires are what in the car with a test light. Best invention evar.
3 main wires
2 individual wires
Black wire= ground
blkthghts
08-04-2003 10:52 PM
