Vg30et Rebuild
Old 08-14-2008 | 12:59 PM
84z31nonturbo's Avatar
Unhappy Vg30et Rebuild
Were is the best place to find a master rebuild kit for an 85 vg30et? I have looked all around the internet and all I can find are re-ring kits, all of the master kits I have found are for the non turbo cars. ANY help would be greatly appreciated.
Old 08-14-2008 | 02:10 PM
www.thezstore.com
www.blackdragonauto.com
www.courtesyparts.com
your local machine shop
your local Nissan dealer
Old 08-14-2008 | 03:01 PM
None of the vendors listed have full rebuild kits, if I have to I will just order part by part, but I would much rather try to find an entire kit. Also, has anyone ever ordered anything from this site? http://www.enginepartsstore.com/serv...san+6+Cylinder
I am not sure how trustworthy it is. The kits are priced very decently, but I dont want to get gyped out of my cash.
Old 08-14-2008 | 03:27 PM
take it to a machine shop, have the hone bumped through it, have everything cleaned, have them check all the clearances then if they find any problems you dont blow up your rebuilt motor. and i would put a rebuild kit together piece by piece. i would start out with total seal rings, clevite 77 bearings, gasket set and a new oil pump. it may cost more to do it this way, but atleast you will have piece of mind knowing that it was done to standard.
Old 08-14-2008 | 04:07 PM
You think thats all I should replace to begin with? Just rings, bearings, gaskets and oil pump? Should I just leave the original pistons as long as there is nothing wrong with them?
Old 08-14-2008 | 04:13 PM
as long as they are serviceable i see no point in pushing out over $150 for a new set. now thats just a few parts to get you started, you still would need things like a timing belt, cam and main seals....etc but it would be enough to get you started.
Old 08-14-2008 | 04:22 PM
Yeah, I had planned on replacing most of the engine, but another question, you think I would really need new cams? I had planned on having the heads rebuilt but I didn't really think I would need to replace the cams. I know if the lobes are worn pretty bad I would have to but if they are ok I could just reuse them for now couldn't I?
Old 08-14-2008 | 04:32 PM
yeah, i was talking about the seals for the cam's the z31 cam's are pretty hard to screw up.
Old 08-14-2008 | 05:17 PM
Yeah, I was going to go ahead and get new seals, I would be very surprised if they are not dryrotted after 23 years. lol
Old 08-14-2008 | 05:48 PM
Also, the engine I am rebuilding came from a car with an automatic transmission, but I am putting this engine into an 84 300zx with a manual transmission. My question is, when I order my oil pump, do I order it for an automatic tranny, or for a manual tranny. And another thing, you said to get "total seal" rings, I get 87mm rings for std bore, right? And how thick should they be?
Old 08-14-2008 | 06:19 PM
i would order one from a turbo motor with an automatic trans. what year motor are you rebuilding?
Old 08-14-2008 | 08:24 PM
85. Also, what thickness are the piston rings on an 85 vg30et?
Old 08-14-2008 | 10:52 PM
i would consult the factory service manual for that, as you can't learn to learn if i tell you the answer.
Old 08-17-2008 | 08:43 PM
my86z's Avatar
JIS has been a place I've used in the past for complete rebuild kits for some of my other cars in the past. I've had nothing but good luck with their kits.
Old 09-01-2008 | 05:30 PM
Thanks for all the help. I pulled the engine yesterday and disassembled today. Pleasingly enough, everything is ok. I'm just gonna put new bearings, rings and seals in and I think everything will be ok. Oh, and of coarse I sent the heads to the machine shop to be rebuilt. No pics of the teardown but I'll get some of the reassembly.
Old 09-22-2008 | 11:49 PM
reddzx's Avatar
Call them and ask for references you can check. Below is their info.
Stephen Carter
Carter Performance Parts Online
235 Island Hwy
Victoria, B.C.
V9B 1G2
250-857-7760
250-478-4109 Fax
email to : engineparts@yahoo.ca
ThaPimpShrimp
11-01-2014 03:00 PM
z31jub
06-07-2012 12:12 PM
SkillZ
18
08-12-2011 05:05 PM
MrEsco326
09-15-2005 07:04 AM
russ240
08-31-2003 11:36 AM
