what happened?
Old 10-16-2006 | 12:39 PM
drkfilldschemis's Avatar
what happened?
okay im in the process of replacing my head gaskets
and im starting 2 loosen the bolts on somethign that has a pully thast connected 2 the bolts
and all this green/yellow stuff came flying out
what was it?
and is it a bad thing that happened?
Old 10-16-2006 | 12:59 PM
green/yellow stuff.... that's pretty detailed.
Could you be more specific? Was it liquid? Gaseous? Solid? Powdery? Greasy?
Green/yellow is usually coolant... but you shouldn't have coolant by removing tensioner pulleys.
Can you post a pic?
Old 10-16-2006 | 01:27 PM
well at first when i loosened the bolt it u coudl hear liek air comign out
so gaseous
then green stuff started coming out with the it in the air
my only guess is it has sumthign 2 do with the a/c?
wats wrong!!!
Old 10-16-2006 | 01:51 PM
Post a picture of what you are talking about.
Old 10-16-2006 | 04:38 PM
rogerz's Avatar
Grumpy & Helpful
well you either pulled your a/c compressor or the water pump.
Old 10-16-2006 | 05:05 PM
so if it was my a/c compressor is that a problem?
Old 10-16-2006 | 06:13 PM
inqui-Z-tor's Avatar
green/yellow stuff ...
ohhh noooo ... you unleashed the alien that all z31s have ....
LOL!
Old 10-16-2006 | 07:08 PM
rogerz's Avatar
Grumpy & Helpful
Only if you like cold air to come out of the vents on the dash. Of course you are now responsible for a 25 kilometer increase in the hole in the ozone layer over the south pole and all the emperor penguins will suffer.
Old 10-17-2006 | 06:36 PM
so if that was my a/c
all it does is not have cold air come out the vents?
cuz i never use the a/c anyways
does it effect my engine in anyway?
Old 10-17-2006 | 06:51 PM
my86z's Avatar
Not one bit!
But it will reduce the effectiveness of the windshield defrost system.
RodMoyes
02-18-2007 03:41 PM
Dakila
10-16-2006 10:32 PM
OldschoolZ
08-07-2006 12:37 PM
SHADY280
12-24-2005 12:28 PM
BaltimoreZ
02-21-2004 10:43 AM
