what kind of engine mods should i do
ok im a noob and this is my first turbo car and i dont know much especially on 300z's
my car is a 84 z31 v6 turbo 5sp.....i was thinkin a k&n intake.....to start with......what does anyone think?? im on a limited budget income lol so pricy upgrades will have to wait a lil bit
best thing to do is a good tune up and inspection. basically makeing sure the car is running perfectly the way it should. then add intake exhaust (better flow throughtbasically) etc.
ooh, and do RESEARCH. lots and lots of research. your best friend is knowledge. learn specifically about your car and turbo systems in general.
what is the best turbo upgrade withing 500? also what size injectors would i need? and how much boos/hp the stock block could hold? i want to get more power but i won't be doing anything with internals for a while, i'll do that in the summer maybe.
That's right...
once again, SEARCH. all of this has been answered.
Originally Posted by johnZboy
We don't talk "car shop" here because it has all been asked, and answered before. So, whatever your question may be, SEARCH for the answer all you wish, but, don't you dare ask us for advice. We are all Internet Z Gods and answering your silly azzed question is beneath us.
my bad about asking the famous noob question but thats what i thought forums were for.....HELP....and not just all searching cause sometimes you just dont have time to look up a hundred threads to find one answer.......o and johnzboy im sure your not a god or whatever..but thanks for being an azz
Humble Apologies...
What johnzboy said... That is the best place for answers...
And what snw said... the 1st thing you should do for the $$$ is intake & exhaust, (check on smog)
Welcome to Z Driver and please use search, as you will find alot of things on upgrades for your Z31 turbo...
see. we dont mind similare questions, but when you ask, what turbo and injectors should i get? thats just something we dont do. if you asked, hey i found "inseret brand and type turbo here" for this price would you think its a good turbo for this car and any recomended injectors sizes. but most likely you can make your own judgement on injectors size based on boost. but really, if you learn about turbo systems and know how they function and react to different things, you can make your own judgements and ask the questions on what you think you like. such as knowing IC systems are a good upgrade with a medium sized turbo and some injectors uped maybe 100CC's or so or more even if you want big numbers but then you need a way to control there percentage they open, you can do a simple SAFC after that or standalone if you want to be a lil crazy.
but if your not going to get into serious racing, then just a lil larger injectors IC setup, intake exhaust (full exhaust) up the boost a few pounds nothing crazy, then make the car purdy.
but first mod is to replace old garbage engine parts/electrical parts or just fix them freshen them up so you know the car is running at its full potential on the current setup.
but if you do search around in teh Z31 sections for mods you can see what others have done and get a perspective on what you might want to do.
remember, this forum has been around for YEARS so all the mod questions have been asked and general techincal problems. the more popular and accepted questions are the ones that have wierd mystery problems you cant figure out that youve attempted to fix already.
we arent here to tell you to search on every question, we arent those kind of people, but at general questions like, i got X amount of money, what can i buy with it.... we arent your parents/local mod shop. thats why the search reference is made.
You can be fast and reliable, but it will cost you.
You can be reliable and cheap, but you won't be as fast.
You can be fast and cheap, but you won't be reliable. Then again, it will end up costing more in the long run, so it won't be cheap either.
If you don't have a lot of money, I suggest keeping the car relatively stock and properly maintained. Proper maintenance is key.
