Will Not Hold Charge
Old 12-16-2007 | 08:04 PM
84z31nonturbo's Avatar
My 84 na wil not hold charge overnight. Its not the altenator because when i put a jump box on to get it running its fine for the rest of the day. Its only when it sits for long period of time whitout starting it. I bought a new battery, but that didn't seem to help, i have gone through the car countless times looking for anything that could be doing this, but so far nothing. Does anyone have any experience with this type of problem?
Old 12-16-2007 | 08:09 PM
its called a short. i will let somebody else take it from there..
Old 12-16-2007 | 09:06 PM
Door pin switch... interior lights... stereo / amp wired wrong, etc etc etc...
Old 12-16-2007 | 09:50 PM
turboboost's Avatar
I'll put 5 bucks on it being the door pin switch. You're gonna have to explore your cars wiring with a multimeter.
Old 12-16-2007 | 10:28 PM
Mhinrichs's Avatar
Mr. Fancy Connectors
not sure if the z`s have this problem but I know a bad voltage regulator can do what your describing. I would probably ignore me and listen to everyone else though.
Old 12-16-2007 | 10:44 PM
if the voltage regulator when out then it would be either over charging and killing the battery or it wont charge/enough to fully charge the battery...
Old 12-16-2007 | 10:46 PM
Mhinrichs's Avatar
Not always, I have a thunder chicken the v-regulator went out. And it wouldn`t keep a charge overnight. Took me months to figure it out because it didn`t fit the profile. Just something else to check.
Old 12-16-2007 | 10:59 PM
WTF is a thunder chicken? and is it internally or externally regulated?
Old 12-16-2007 | 11:23 PM
Mhinrichs's Avatar
Ha, 1987 ford Thunder Bird. And it was externally regulated.
Old 12-17-2007 | 11:43 AM
Whats a door pin switch?
Old 12-17-2007 | 12:13 PM
oh man....
The name should give it away... it's the switch for the doors. When you open a door, it pops out and turns on the interior lights.
Old 12-17-2007 | 12:41 PM
ok, i know what your talking about. I know there is nothing wrong with that, the lights turn off when i close the doors.
Old 12-17-2007 | 12:42 PM
Where would be the best place to start with a multimeter?
Old 12-17-2007 | 01:12 PM
KasbeKZ's Avatar
Pr0n Addict
I'd try a test light on the hot wire of all the accessories. the ones that you can't tell that they are obviously on just by lookign at them of course...
Lanoi
04-09-2010 10:53 AM
flicktitty
13
02-26-2006 02:50 PM
300zxBoi
06-02-2003 12:01 PM
Skully
05-07-2002 01:57 PM
Quick Reply: Will Not Hold Charge
