Won't accelerate
Old 07-07-2006 | 10:39 PM
my86z's Avatar
Won't accelerate
I just got my 86 N/A running. And now, when I'm in any gear, it won't accelerate. It's almost as it I'm only making about 30 hp. I'll put my foot to the floor, and it'll accelerate like it's a snail.
Timing is good. Cams are dead on. Ignition is set to 20* BTDC.
Other than removing my cat, to check if it's clogged, is there anything else I should be looking for?
Wink
Old 07-08-2006 | 12:20 AM
Why start w/ the more difficult stuff first? The cat should be the least of your worries.... unless your car is a complete rust bucket & the exhaust is already about to fall off the car.
Check EVERY sensor connector & all main grounds.
Old 07-16-2006 | 06:08 PM
my86z's Avatar
Guess what.
IT'S FIXED!!!!!!!!!!!!!!
Today I was working on the car, and what I once thought was the injector campaigne wires to my right side injectors, was actually the main feed wires to all three on that side. For some reason, someone, probably the previous owner or the one before him, decided to cut them.
I just spliced them into the injector harness on that side and tried to fire it up. It took two times for it to catch. But now it runs awesome. Blip the throttle, and it goes to 6k almost immediately. Sounds awesome when it's firing on all 6 cylinders.
Thanks for all of your assistance!!!
JDLHP
11-28-2013 10:21 AM
Reaper
03-27-2013 02:14 PM
Bucket280z
03-07-2012 06:01 PM
BaltimoreZ
05-16-2004 05:16 PM
justiceboy
05-05-2003 02:06 PM
