1990 radio harness
I'm assuming you mean to connect an aftermarket stereo to the factory wiring right?
Walmart, Kmart, local auto parts store, best buy, circuit city and radio shack all carry harnesses. Be aware that if you go to the major electronics stores you'll pay vastly more than if you just get the $7 one from walmart.
The regular Nissan one will work. They told you that because of the stock Bose system. It'll work. Are you using the stock Bose speakers? If so, I got a handy trick that'll help you use your aftermarket deck with the stock Bose system.
ok, so after you get the walmart harness, you'll have to make a trip to Radio Shack. Pick up two pairs (that's 4) of rca plug blanks. They won't have any wires coming out of them, just plain plugs. The center is the positive and the outer casing is negative. Wire the blank rca's left and right, front and back to the walmart harness. They're attached to the speaker wires from the harness. The rca's are then attached to the preamp outputs of your aftermarket radio. If your head unit only has one set of outputs instead of front and back, then you'll have to also pick up from walmart or radio shack some "2 female to one male" Y-style rca jacks. Then on the harness just hook up your constant power, switched power, ground, and antenna/amp turn on lead. Done.
What this does is emulate the Bose head unit, in that, the Bose head unit sends a preamp signal to the Bose speakers. Since each speaker has it's own amplifier, sending it an already amplified signal will result in noise and distortion at relatively low volume levels from your head unit. The better the head unit's preamp voltage the better the sound. Most of your higher end head units will have anywhere from 2-6 volts of preamp power which should yield you noise and distortion free sound at relative high volume levels. The only thing you guys might want to add is a pair of tweeters for the front and/or a sub. The stock speakers aren't the clearest or cleanest sounding speakers but they're extremely sturdy. The amps'll go before the speakers do. A sub will obviously beef up the low end.
Thanks for the tip. I just finished installing the new player, and I probably couldn't have done it without your help! Those little RCA tips are a biatch though!! Wasn't there an easier way, like if I got some RCA cables and cut the tips off, couldn't I simply twist and tape instead of trying to wire those tiny little pain-in-the-@$$ jacks myself?? Sigh, I never want to see another RCA jack again...
And since you mentioned the amps going out, I think one of my speaker/amp units may die soon. From what you've said, it's most likely the amp. Is that easy to find and easy to install? Any info would be greatly appreciated buddy. Thanks!
Here's how it looks now:
Originally Posted by Copper727
Hey Rizz,
yeah, you could've done it that way. I just found it easier and more reliable the other way. I didn't have any trouble with them.
Congrats to the new baby rookie!
Copper-
Have I been living under a rock? When did you buy the TT? I remember discussing the possibility if you purchasing one, but I don't recall the announcement that you finally made the final decision. I thought it was going to be yellow?
Copper-
Originally Posted by 91zxtt
Copper-
What size and finish do you want those rims in?
Any specific brand tires?
Have you thought about going with 17's up front and 18's in the rear? That's what I have. Unless I was fed a line of crap by Stillen, that's what Steve Millen used when he raced the Z32. He found that setup performed better than 18's all the way around. I have the same tire sizes that you mentioned. It looks great!
DanRC30
11-07-2013 03:28 PM
cobralini
02-17-2013 08:06 PM
therbst
FS: 300ZX (90-96)
09-12-2009 05:46 AM
konahrtist
11-19-2005 11:34 PM
