1999 front fascia
If there are the same amount of wires all you should have to do is match up the positive and negative, also you might want to check to make sure the voltage and amperage requirements for the new lights are teh same as the old ones
The connectors are not the same...you will either need to see if the shop you bought the bumper from has them. Or take the turn signals down to your local dealership and have them look around and match the harness up with a repair one that they carry.
I ran into the same problem when I bought my JDM side repeaters on my Z...I had to go searching around and I discovered that the harness was similar to the turn signal plugs. SO that gave me a starting point.
