after market power locks
your car comes stock with power locks. If you asking about an alarm, yes you just have to a couple things under the dash in the bottom left corner and you can put a starter in. But why would you want to? Are you gonna be drivig it in the winter.. HOPE NOT
lock
i had to put an after market door lock motor in the driver door because it does not come with one. It is a slave system that uses the signal from the keyhole to control the passenger side lock. Just put a motor in on the driver door, wire up two relays and hook it to your alarm and yo are golden.
Heat Rave R
10-11-2004 10:18 PM
