alarm!
Guest
Posts: n/a
alarm!
ok people...i have had my Z for about a month...just tonight i noticed it has an alarm...locked the doors and when i went to get into the car, it went off! is this a factory alarm maybe? if so, what are the procedures to shutting it off? any info is good info! thanks
Well I've noticed on my Z if the window is partially down and you reach in through the door to unlock it, an alarm will go off. The way to stop it is to put your key in the outside unlock and lock it then unlock it...I don't know if thats what you are talking about but it works on mine..
1st thing is to find out what type/model of>
alarm it is. Try asking the previous owners or look for receipts (often left in glovebox).
Otherwise it is the old rip out some of the underdash drivers side and look for a suspicious black box (usually size of a cigarette pack?). It will look "out of place". If there are no markings on it- usually not - then take it to a local auto alarm store and get their opinion.
cheers
cheers
cheers
cheers
Do you guys drive on the other side of the road in Austrailia? Cuz if so, the ECU and other electronics are on the Passenger side on our cars here in the U.S. Just a little correction.
Actually it'll be marked. it'll say CONT-ASSY THEFT WARNING. The alarm box will be rather small. About 3x3 inches with a blue relay attached to the side of it. It'll be facing the ECU, so you'll see the back of it first. Two screws and undo the relay and it's removed.
How do you know it will be called>
CONT-ASSY THEFT WARNING? Is that a standard alarm on all zeds in USA?
Sounds a bit weak if all the thief needs >
As far as I know yeah. It'll have a that label on it followed by some numbers below.
Same. Unlock throu window, beep beep.
I went to the dealership they told me that this car didnt have a factory alarm system. But i have the fuse thing and the fuses in it. And IT HAS AN ALARM!! How would I go about getting a remote for the old Box Mobile.
