Another Turn signal question
So, I got back my car bout a month ago from the paintshop and the body kit is on it, and the oem turn signals don't fit in the body kit. So right now I have it rigged up so it's still legal, but I need to fix it so it looks right, I don't want it to be rigged up any longer. The wholes are about an 1 1/2" too small. What could I use to put in there.
get some honda side markers and use them as your turn signals, they are about an inch by a half an inch, and then all you need is some LED's or something as your parking lights. i had that on my Z when it had that combat style front bumper. i mounted LEDs on my fenders ( one on each side) LED looked just like that side marker with 3 single LEDs inside it.... i got nothing but the compliment for it..... i figure i'd just throw in an idea for you
well, i just took the stock wiring and connected it those new leds, and turn signal, if i remember correctly it was pretty straight forward. just take a volt meter, and a wiring diagram, and you should be fine. it's been a while since i did it
jiyu-z-chick
06-29-2006 10:16 PM
