fast blinker
Had the same problem, it only happened when the lites were on(h-lites). left flashed fast like a bulb out and the right flashed normal. Had corrision on the contact in the left front, took out cleaned and replaced. it fixed it. Those cars are just too smart it even knew I had the Japanese bulbs still in the tails when I changed to the jspec. Different resistance, showed the Tail warning indicator on the dash.
http://300zxclub.com/showthread.php?t=23996
11. If the turn signal blinkers blink at a high rate occassionally (usually just on one side), check the ground on the side that is blinking too fast. It can short out and may even cause it to stop blinking. An electrical shop can redo the ground for about $25.
