Headlight Removal
Headlight Removal
MY passenger headlight got bent the the left when that el camino hit me where exactly are the bolts to remove the headlight cause I tried to use the J-Spec Install pics but there is no detailed picture showing the bolts..any help please.!
There are two nuts in the front, one on each side you need to remove(per headlamp). There are also two screws in the back, one on each side(per headlamp). Your fascia will have to be off of course. The two rear screws that are on the intake side are a bitch to get on and off so be patient as they are kind of hard to get to.
yeah I know but can someone take a pic or a somewhat pic of what these damn bolts look like There are like 11111111111111111 screws on that headlight..
the screw that's on the front adjusts the left and right direction of the light.
to adjust the up n down you'll have to dissasemble the fog light and there's a screw on the inside that adjust the height.
