The HIDs are On.
Old 03-04-2008 | 08:59 PM
Darkmann's Avatar
The HIDs are On.
It was a very warm day today so at lunch time I decided to install the HIDs. See the pics for yourself. They lighting is definitely way more bright than the OEM's. However, the light pattern is sub par - I can see the dark areas caused by "light shadows" as the patters criss-cross between the left and right lamps. Also notice that the retrofit doesn't show the characteristic inverted "L" of OEM HIDs. I drove around a few streets tonight and no one flashed me. So I suppose I'm not bothering oncoming traffic. My guess is that the retrofit is fine. I think the issue is that the design of the OEM lens doesn't allow the HID beam to scatter like OEM non-HID would. Just like NismoPick said - we get what we pay for!!! I'll ride as is because I see a lot better with these on. I have 8000K bulbs and would try them on just for looks!!!
Before HID Install (Bimmer on left, Z32 on right). I'm standing, maybe 8-10 feet from both cars
After HID Install - the Z gets much brighter, and actually mimmicks the Bimmer.
Z on Left (note how better sharply defined the Bimmer's pattern is)
Closer Shot - the Ghostly bluish pattern on far right is from the Z's lights - the scatter goes that far right!!
Old 03-04-2008 | 09:01 PM
tonsoffun300zx's Avatar
West Coast!
cool looks great!
Old 03-04-2008 | 09:14 PM
Barry'Z(NJ)'s Avatar
General Z User
Your results are typical.
Though judging from the comparison, you could adjust the Z headlights up just a bit.
Old 03-04-2008 | 09:21 PM
Darkmann's Avatar
That's good to hear. The headlights are aimed correctly per Maryland requirements and I actually see great when driving.
Old 03-10-2008 | 07:53 PM
General Z User
Well here's mine for comparison, I'm only talking a couple inches up at the current distance...
Old 03-11-2008 | 05:21 PM
Darkmann's Avatar
See what you mean Barry. I'll raise mine up a few inches.
Also, I took my pics standing outside. I wonder if that'll make any difference at all. I assume that your garage door is the standard door, thus we can use the lower slats as reference.
Old 03-11-2008 | 05:37 PM
KasbeKZ's Avatar
Pr0n Addict
you'd get better range if you aimed them up just a tiny bit. looking good though.
Old 03-17-2008 | 08:44 PM
General Z User
Yes, with the car about 25 feet from the door, bring the low side cut-off to, or just above, the lowest break/hinge.
Old 04-03-2008 | 05:57 PM
domsgarage's Avatar
Tough Guy
I put HIDS in a while ago, they always look so good.
3riCJbOi
10-05-2009 12:40 PM
3riCJbOi
04-20-2008 01:47 AM
entropy31
03-01-2006 09:29 AM
ZXDude90
53
04-28-2005 06:59 PM
300zxtwintrbo91
09-16-2002 05:25 PM
