Lighting - PIAA Xtreme White Plus
#51
My reasoning is DON'T BUY CHEAP CRAP, not: only buy BMW! There are good aftermarket kits out there, but again... when they are cheaper: beware. That is all.
#52
Snw and entropy, you guys are absolutely correct. It's almost impossible to conceive that one will be stopped for this installation. My concern was what effects it would have on oncoming traffic. But I didn't consider the fact that the projector lens is similar to what the OEM xenons are enclosed in. snw, I really tried every wiggling trick I could. It didn't work. I will give it another try tomorrow, maybe I'll get lucky. I really don't see why it wouldn't work, unless the second ballast is also bad!!!!
#55
only had silverstar's in my Z32 for about 3 months before i got the HID's swapped.... other wise they light everything really well. and i think my friend has had his in his honda for a couple years now. since early sr. year at highschool at least (sophmore in college now)
#56
Well, I'll have to keep these HIDs retrofits
like it or not. I took the package to UPS and was quoted $175 to shipp to the People's Republic, Ouch!!!! That's way more than what I paid for the thing, so, I'll keep the pieces and try again, maybe this weekend. Meanwhile, if anyone wants them, make me a deal - you get them, test to make sure they work and then pay me. After this weekend, I'll pretty much know whether or not to keep them.
#57
Wow, sorry to hear of your trouble with the kit. I still have mine and I have a few friends in the area with the same kit with no issues.
Are you sure you're getting all the wires hooked-up properly? It's not difficult to reverse the polarity on the plug that goes to the ballast, and that will prevent the bulb from lighting.
#58
#59
Got them both working
Turns out it was a polarity problem like Barry'Z suggested, basically due to bad design. Like I'd posted earlier, the design of the male piece would not allow it to engage the safety tab on the OEM female socket. I turned it around and prayed not to blow up anything and it worked fine. However, in this position, the safety tab is completely disengaged, though the assembly stays solidly connected. I'll look for a way to reverse the cables in the male plug so the safety tabs engage properly. But for now, I'm OK. Will make the installation permanent when I install a POP charger - there'll be room there to safely store the ballasts.
