Replacing Shift Knob?
Old 05-18-2004 | 09:14 PM
My Fairlady Z's Avatar
Ruined By Spudz
Replacing Shift ****?
I am trying to replace my factory shift **** with a new factory shift **** and i cannot seem to get the stock one off. I have tried twisting it off and it doesn't budge. Can someone please aid me in my shift **** dilemma
Old 05-19-2004 | 05:51 PM
Shameless's Avatar
when i took mine off it was just an issue of pulling it off man. dont understand why yours wouldnt be the same.
Old 05-19-2004 | 06:54 PM
tsefreeflow's Avatar
I'm Chillin
Well, if it has never been taken off before, then it is sealed on there with some lock tight stuff. You need to break it loose. Now I never had to do it because mine just came right off, but I heard that you can wrap a towel (wet i think) in the proper direction and pull on the end of the towel and it should twist off. Good luck!
If that does not work, check TT.net for a write-up on it. I think i saw one there, but I might be imagining things.
Old 05-19-2004 | 08:02 PM
Ruined By Spudz
Alright thanks for the imput, I'll go try your suggestions right now...
Old 05-22-2004 | 03:21 PM
Riz Z Speed's Avatar
Administrative Brown Guy
If you don't mind destroying it, take a pipe wrench to it.
Old 05-23-2004 | 07:12 PM
Ruined By Spudz
I tried everyones ideas and they still dont work..and i dont really want to wreck it..does anyone know if there is some kinda of screw to undo that is under the boot or something cuz i cant get it off for the life of me!!!
Old 05-24-2004 | 04:55 AM
lol no, it's only held on there with locktite lol.
if you don't wanna destroy it, let's combine a few suggestions. Wrap the **** with a towel/s and then use a large pipe wrench/locking pliers. Keep going until it gives. One way or the other, it'll come off.
Old 05-24-2004 | 09:20 PM
Ruined By Spudz
hmmm yes but when I put the wet towel on it and put the wrence to it..it just started tearing at the leather on the ****..so i dont know what to do..i guess i will jsut deal with it cuz I've turned it about 1/4 of a turn and now it won't turn back hehe well i guess i will keep trying and trying till it comes off thanks for all the advice rizzspeed, tsefreeflow, and shameless.
Old 06-16-2004 | 09:14 PM
Z_WRECKER's Avatar
ELBOW GREASE!!!!!!! you can do it!
Old 06-17-2004 | 02:45 AM
btw, did you ever get that switched??
Old 07-23-2004 | 06:31 PM
Z1 ZONLY's Avatar
Are you positive you're trying as hard as you can? If the **** is in good shape you can sell it for a good $40, so try hard not to ruin it. No matter how hard you twist on that thing (counterclockwise), you can't break the shifter, so go all out!
Tsuka89
09-21-2011 11:11 PM
bojo68
04-05-2011 06:14 PM
Smittyz33
01-04-2006 05:43 PM
WildmaN
35
05-06-2005 03:05 PM
FSSMan3
11-21-2002 11:29 PM
Quick Reply: Replacing Shift Knob?
