Stillen Front Facia
Stillen Front Facia
I really like the Type III with the discrete lip (http://www.stillen.com/product.asp?i...AN&model=300ZX)
Besides painting, how difficult is this to install? Does it install over the OEM front end or is there some hidden work that needs to be done for proper fit?
...99 j'spec is the sexiest
The JSPEC does look nice. I just don't like the IC air scoop - makes the car look like any other front end out there. The finned OEM scoop is original and unique. You see it and you know immediately that it's a Z32 TT. I like that.
BTW, back to installation - I checked my front end and it seems like the lower lip and the rest of the bumper are one molded piece. So, doe the JSPEC and Stillen then just bolt over the OEM lower valance or am I missing something?
I installed my type III. I went ahead and paid a shop $100 to paint it because I have no experience working with urethane.
On the lip itself, I wasn't really happy with the overall quality of the product. That being the way it came out of the mold and the way the flash was trimmed off. Kind of buggered up a bit. The fitment was o.k. It needed to be trimmed a little here and there. The biggest issue was with the ends where it wraps around the stock fascia by the wheels. On one side, I had to add some shims because of a gap where it needed to be riveted on. The other side needed some trimming and then heating to get it to stretch around the corner of the fascia. The install instructions are kind of poor. If you haven't installed anything like this before, you'll want to pay to have someone do it for you.
Overall, I really like the unique look of it as opposed to the stock look or the well over-done look of the J-spec version. On that note, I do have a J-spec fascia laying around that will most likely go on the '94 when it gets a TT swap.
You have to remove the stock fascia to install the lip. It slides over the stock lower portion and rests in the groove where the existing black stripe is. You install a couple of bolts/nuts in the front on each side of the large opening. You get some double-sided tape to make the lip stick around the sides, and you install some pop rivets where the lip raps around the wheel openings. Separate from the instructions, I also installed some short sheet metal screws with glue around the sides where the stock black stripe is. I did this instead of using the double-sided tape.
oh jeez i feel like a tard. i didnt even see the word LIP in his first post. i thought it was the whole front fascia. my bad.
Originally Posted by b300z
its just a lip, but other than that i dont know how it works
No, the fascia doesn't *have* to be removed to install it, but if you want a good install you'll remove it. And quit being a p*ssy, removing the fascia is easy.
As for the fins (which are usually called gills), go look at the pics that were posted... there was at least one good one showing it.
BTW, Type III > JSpec
...And quit being a p*ssy, removing the fascia is easy.
you can always.....research
dont just half *** the job. remove the entire bumper. its not that difficult. and dont expect owning/modding a z32 is going to be easy.
you have to order the TT lip (like you should anyways) because it is wider than the n/a to allow space for the side mounts
dont just half *** the job. ...
so how is the seem between the fascia and the fenders filled like on this one?
http://www.speedyzx.com/Jspec/fascia.html
you reckon they just stuck bondo in there? that seems like it would crack to me. fiber glass?
yyyktk1
02-28-2013 09:44 AM
SR300ZXTT
19
12-04-2012 01:40 PM
