windows
Guest
Posts: n/a
Re: windows
I'm assuming that the windows you are referring to are the rear quarter windows, since the doors of the two models should be the same size, hence the door windows should be the same size as well (Maybe not). Since the 2+2 is stretched by some 20 cm or so over the coupe, it makes sense to me that in order to keep the visual porportions similar on both models, Nissan would have to stretch the rear quarter windows on the 2+2. The only sure way to tell is to take some measurements on the two cars. Let me know what you find out. I'm curious to find out how Nissan solved the problem.
