ball joints
ball joints
Ok so i have the tie rods (inner) and now i need to get the BALL JOINTS..my question is, does each have 2 of them..cause all i can find is the LOWER, or in any case should i buy 2 of them? (the lower that is)
im cool with the tie rods i got one for each side, my que Q is about the BALL JOINTS, cause most cars have 2 per side, and when i look for them it only shows LOWER BALL JOINT, so is there any UPPER or do they only have 1 per side..thanks for replying
Sorry, I don't know where I got off track on the rod ends. Working & surfing don't go well together.
I searched a number of parts sites and there is no mention of an upper ball joint. In doing a search on tt.net, I could only find one thread where someone states that the 1990 model FSM shows a king pin attaching the steering knuckle to the upper control arm.
Edit: it's a kingpin right here in the FSM. --->>> HERE
kool, tanks man im just going to buy the lowerand then se if that will do..ill keep you posted,..
And by the way, i like your wheels bro, ive ben looking for a set that looks good on my white Z, so far my only choice is the rims for the 35th anniversay model of the 350 Z....loooove the stock look
Cyproz
06-13-2014 09:49 AM
