clean title. but major weld marks on the chassis
i have a POS black 300zxTT. its all stock except for the honda accord head unit i have installed. and used telephone wire to hook up the speakers....YES it is a true piece of sh##T.
Anyways. the cars been in an accident, and there is damage to the right front end. the previous owner then took the time to take the car to a wacked *** mechanic. who has welded the front piece of the frame/chassis with a sheet of 'metal', which originally needed replacement.
Now i want to replace this part but i cant find out the correct name for it. It is a part of the chassis which goes underneath that car towards each of the front tires. It holds the oil cooler in its position and is right behind the radiator. If anyone can help me with the name of this piece, it would help out a lot thanks
it's the radiator. support beam. goes from side to side of the car am I right? if so. that is what it is. mine will eb replaced as well. I will be replacig most of my front end. with a JDM front clip piece. make sure u havea profecional Frame shop do it. it wont be cheap. btu trust.U get what U pay for.
radiator support beam nd then some...
the radiator support beam is kinda mangled up. but its not the exact piece that has the weldmarks on my car. there is a chassis piece located behind the radiator support, which the oil cooler sits on. unlike the radiator support it does not extend from the top to the bottom of the car, it juss sits at the bottom, looks like a beam, part of the chassis of the actual car. i cant find the name for the piece. its the piece that supports all the steering components...
FubarI33t
03-31-2013 07:26 PM
ricksilvia
10-10-2012 06:17 PM
dave1030z
FS: 300ZX (90-96)
05-02-2007 10:05 AM
