suspension..
Old 10-02-2007 | 10:29 PM
cake872's Avatar
suspension..
How do you grease up the ball joins on the suspension? mine squeaks loudly when i go over bad areas. Im not sure if thats the prob but any suggestions?
Old 10-03-2007 | 01:40 AM
MikeZ's Avatar
wrong section bro'...
Old 10-03-2007 | 04:33 AM
at least he got it in the z32 section..
Old 10-03-2007 | 09:45 AM
entropy31's Avatar
The Cake Is A Lie!
Moved to 300ZX (Z32) Brakes, Wheels, Suspension and Chassis.
Old 10-04-2007 | 04:43 AM
CanyonCarver's Avatar
Jack Of All Trades
Surprisingly, the z32 is famous for having a hood squeak. Seriously. If you haven't, you might try lubricating the hood latch and then adjust it down a little to hold the hood tight.
The ball joints and rod ends are lifetime sealed. There is no lubricating them. On my car, when it's colder than normal, I have a squeak in my left front shock, upper spring seat. It goes away after a couple of minutes of driving and I haven't done anything about it.
Old 10-04-2007 | 09:41 PM
cake872's Avatar
Um thanks for the guy with the tip but for everyone else am i not in the suspenison section unless our computers post labels differently.
Old 10-04-2007 | 09:50 PM
This should be a hint.
Old 10-04-2007 | 09:59 PM
entropy31's Avatar
The Cake Is A Lie!
you ARE in the suspension section, because i moved the thread here.
Old 10-04-2007 | 10:08 PM
yeah it possible... very possible its the hood, you can try adjusting the ruber bump stops on it as well, maybe put a little grease on them.
Old 10-04-2007 | 11:13 PM
MikeZ's Avatar
"Dee-Dee-Deee!" lol
Old 10-05-2007 | 10:29 PM
cake872's Avatar
Oh damn, sorry I feel like a clown. Didnt realize is all. Thanks thou. If it doesnt turn out to be my hood do you think i might need new bushings?
Old 10-06-2007 | 12:47 PM
MikeZ's Avatar
they are like $2
Old 10-07-2007 | 10:55 PM
cake872's Avatar
Well I dont just wanna buy something and it not be the prob but yea i think ill do those weather or not.
Old 10-31-2007 | 11:52 PM
cake872's Avatar
My friend was having the same prob. I sprayed up all the joints on my front end with diseal fuel and it killed the squeaks. WOOOPIIEEEEEE
Old 11-01-2007 | 09:46 AM
Fuel + rubber & grease... hum... I like where this is going.
Old 11-01-2007 | 02:23 PM
cake872's Avatar
Well it looked to me like those joints were lacking in grease if thats whats even suppose to be ther but it was a quick fix. I thought my front end was gonna fall out for all the noise it was makin. and I did check to see if anything was lose.
Old 11-01-2007 | 04:27 PM
b300z's Avatar
caught the z fever
so you replaced grease with fuel. next youll replace the bushings and rods
Old 11-01-2007 | 09:53 PM
91zxtt's Avatar
....but hey, the squeak went away so all must be ok now....
Old 11-02-2007 | 04:25 AM
MikeZ's Avatar
Did you adjust the hood latch? my squeak went away...
Old 11-03-2007 | 07:28 AM
cake872's Avatar
Na my hood wasnt makin any noise but I do need to adjust it because my hood rest close to an 1/8" to high. Is it easy?
Old 11-03-2007 | 07:18 PM
91zxtt's Avatar
Um....yes....find the latch....add lubricant. It's easy unless you're a retard.
Old 11-04-2007 | 09:48 AM
cake872's Avatar
If the lastch is loose then lub wont do anything. And I dont hav a latch noise problem.
280zdude
04-12-2010 05:44 PM
calvinD
04-29-2003 02:33 PM
mountain
03-18-2003 11:18 PM
thecrowdescends0
12-09-2002 10:11 AM
onelegmurphy
10-30-2002 12:15 AM
