who has wheel spacers?
Old 02-15-2007 | 08:44 PM
zomg's Avatar
does anyone have wheel spacers for their z? i have a 90 n/a and was wondering if the stock wheels have the grooves on the inside of the wheel to install them.
Old 02-15-2007 | 08:48 PM
why would you need spacers on stock wheels????
Old 02-15-2007 | 09:01 PM
entropy31's Avatar
The Cake Is A Lie!
dont use spacers. ever. no matter what. they are dangerous.
Old 02-15-2007 | 09:47 PM
b300z's Avatar
caught the z fever
to make the wheels flush with the fenders.
i know some people who have them, and they are holding up fine. but they can be dangerous. make sure they are installed correctly and everything.
Old 02-15-2007 | 11:06 PM
oh... yeah dint think of that... mine came with after market wheels wider than stock so i guess i never noticed it... i was totally un aware or this tire not flush with fender thing goin on
Old 02-16-2007 | 04:08 PM
zomg's Avatar
yea i was thinking that i could put some on...to fill up the horizontal gap towards the fender on rear and maybe front. but if they are dangerous the its out of the question.
Old 02-17-2007 | 06:59 AM
CanyonCarver's Avatar
Jack Of All Trades
I don't think wheel spacers are dangerous as long as you use the hub-centric kind and maintain the proper wheel stud length and thread engagement. If you go to the thicker spacers, you need to use the kind that bolt to the hub and then the spacers have their own wheel studs mounted in them.
I wouldn't use spacers myself, especially on the front where changing the effective wheel offset can have a significant impact on steering and suspension dynamics.
Old 02-17-2007 | 02:55 PM
zomg's Avatar
so say with 15mm in the rear or something like that, it shouldnt harm the car?
Old 02-18-2007 | 12:26 AM
15mm is too much.
either use a 7mm or narrower spacer ring or go with the bolt-on 5 to 5 adaptors. Those would be a minimum 30mm which is too much.
If the 7mm ring doesn't do what you need then just buy wider wheels. Have you looked for the stock TT wheels?
Old 02-18-2007 | 01:57 PM
napoleonzheking's Avatar
F5 Hero
I have spacers in the front, but replaced the studs with longer nismo wheel studs and open ended lugs. No the stock wheels don't have grooves.
Old 02-18-2007 | 03:01 PM
zomg's Avatar
yea ive looked for tt wheels, not successful in finding cheap ones....so the stock wheels wouldnt be able to have spacers without getting the kind that have extended studs?
Old 02-18-2007 | 03:46 PM
Riz Z Speed's Avatar
Administrative Brown Guy
moved to 300ZX (Z32) Brakes, Wheels, Suspension and Chassis
Old 02-19-2007 | 03:15 AM
F5 Hero
no you need to replace your studs with longer ones... those extended studs things (if were talking about the same thing) are bull ****....
Robert Mancia
12-02-2013 10:23 PM
dhall1414
12
03-30-2013 08:07 AM
81 Black L28E
08-18-2005 08:49 AM
AV240Z
07-17-2003 02:08 PM
nepcom
11-27-2001 11:12 PM
